Stage III clutch overkill?
Old Feb 6, 2013 | 01:34 PM
89iroc89's Avatar
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Ok so here is what I have... 91 firebird GTA Ws6 G92 welded SFC and torque arm. My 5 speed is slipping when I gun it so it obviously need's a new clutch. I am looking at these stage three clutches and hear they hit pretty hard which I like. I love banging these gears and such.
Is a stage three overkill? Or will it be fine. My mod's are only open air filter and air foil and smaller mods and exhaust. So can I put a stage three in knowing it will take my abuse? or do I stick with the oem clutch? I really do not want to have to baby it.
Also, what am I looking at for time wise? I will be replacing it my self, and my dad and bro will help, so maybe what... A day? Any hidden things I should be careful of?
Old Feb 6, 2013 | 02:25 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Stage III clutch overkill?
Stock clutch is more than enough to hold a relatively stock motor. Plus I would rather have a little give in the clutch to help the T5 live.
Old Feb 6, 2013 | 02:31 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
Alright, so what about stage 2 then?
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wrong place to have give, you buy a lot of clutches that way.
The give should be the tires.
Old Feb 6, 2013 | 03:41 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
So back to a stage three clutch? LOL
Old Feb 6, 2013 | 03:56 PM
David 91RS/Z28's Avatar
Yes, overkill. I wouldn't do it. It would most likely have some chatter on a normal takeoff especially if its a puck style. Full face disk are more forgiving. Might consider going with something like a SPEC Stage I or II or a Centerforce. I have used a CF with my current 355 setup with very good results. Very driver friendly yet has held very well.
Old Feb 6, 2013 | 04:26 PM
LilSki's Avatar
Car: 85 Trans Am
Yeah I guess you are right. But either way a stock 305 should not overpower a stock clutch. Most I would go is stage I or II like David suggested.
Old Feb 6, 2013 | 04:45 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Zoom Clutches#770-MU1675-1A
Pressure Plate Dia.: 10.4''
Disc Spline: 1-1/8'' x 26
Diaphragm
Drone358
Dec 10, 2015 08:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
