10 bolt build to hold reasonable hp?
Old Feb 12, 2013 | 05:24 PM
89camaro355's Avatar
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
So finally got my car together and my local track open in 2 weeks. Can you build a 10 bolt fairly inexpensive? (cheaper then a 12 bolt or 9"). Theres 4.56 in there now. I am running slicks but not launching off the converter. Just want to launch hard and not worry about breaking the rear.
Old Feb 14, 2013 | 07:01 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 10 bolt build to hold reasonable hp?
If you have the 90-up 28-spline axles, or the best aftermarket 26-spline axles, then the R&P is the weak link. The only help is one of those aluminum rear covers with the bolts that pre-load the carrier caps. And run good synthetic lube. The next weakest link is the differential cross-pin. There is an aftermarket upgrade, it takes a little light grinding of the teeth on the ring gear to use it. Don't grind the pin.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
johanlindgren
Aug 16, 2015 12:16 AM
