9" center with 10 bolt axles and tubes?
Old Feb 12, 2013 | 07:30 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Could the axle tubes from a 10 bolt be welded onto a ford 9 center section? I was just thinking about converting a junkyard 9" to fit a a 3rd gen and thought of that. Would the axles be able to work with the ford gears? or would custom ford axles be needed with the GM bolt pattern? if it's even possible....
Old Feb 12, 2013 | 08:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9" center with 10 bolt axles and tubes?
Custom 9" axles will be required. 9" axles are bolted on with a retainer over the axles bearing. GM axles are held on by c-clips inside the carrier. There's no way you're going to retain the 10 bolt axles inside the 9" housing.
Using GM axle tubes in a 9" housing still won't allow you to use a torque arm. The 10 bolt mounting brackets can easily be cut off the 10 bolt tubes and welded onto 9" tubes except for the torque arm mount.
By the time you're finished modifying and fabricating, it can be a lot cheaper and easier to just by a 9" housing package.
Old Feb 12, 2013 | 10:28 PM
Gsoleski's Avatar
Car: 1984 Z28
Good info that's what I was looking for. I'm pretty sure I saw a torque arm mount for a 9 bolt a while ago made by spohn maybe?
Old Feb 13, 2013 | 05:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A torque arm mount for a ford 9", not 9 bolt, was once available from Currie but I don't know if they still sell it separately. Spohn may offer one but you would have to check.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
