Redrilling backing plates on Ford 9" rear
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
My axle is a Moser 9", with Big Ford old style housing ends. The drum brakes I have, are Big Ford new style. Not a huge difference, but wondering if i can redrill the backing plates for my axle? How is the best way to get it centered?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Redrilling backing plates on Ford 9" rear
Make a template using the center hole/bearing as a guide. Weld up the old bolt holes then use the template to locate the new holes that need to be drilled.
The old style should be 1/2" holes while the new style should be 3/8" holes.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
