nwc t-5 leaking
Old Feb 25, 2013 | 12:30 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
nwc t-5 leaking
ok so its from a 86 firebird v8 and i have been using atf b/c thats what the repair books and shops and part stores are telling me, however looking around online it looks like im suppose to use gear oil so which one is it? atf or gear oil, and if gear oil what weight?
as for the leaking would useing gear oil instead of atf stop it till i can finally get a rebuild kit? the part it is leaking from appears to be the front... umm bearing cap?(its the cap looking thing that by looking at it you can tell if its wc or nwc, below the input staff) the tail staff is dry, the input staff appears dry but around the cap is broken rtv sealent and fresh atf fuild. so now the question is can i remove the sealent and put fresh rtv sealent or replace the seal with out taking it all apart to stop the leaking?
Old Feb 25, 2013 | 04:49 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: nwc t-5 leaking
If it is leaking there the case is stretched and is just about toast. The reason the T5 is so weak is the case is weak. When you put any power into them the main gear pushes the counter shaft away from the main shaft. And since the case is weak is ovals the holes causing it to leak. Basically once it starts leaking it's toast and no rebuild kit will fix it as the case will just continue to stretch.
As for the ATF gear oil thing that has been the source of a lot of different opinions over the years. The WC T5 can only run ATF. The non WC T5 can run either.
Old Feb 26, 2013 | 07:48 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: nwc t-5 leaking
****. well thanks for the info. guess ill try to use rtv sealent and switch to gear oil, try and buy me some time till i can get a new case or trans.
Old Feb 27, 2013 | 10:00 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: nwc t-5 leaking
just had an idea can i weild it? lmao i rly dont want to spend time trying to find another trans. and i rly dont think the rtv sealent and gear oil is gona stop the leaking >.> but i need this trans to hold out till i can get a new one.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
