Gearing
Old Feb 25, 2013 | 12:31 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Gearing
I have a 89 trans am with the lb9 and has the stock 2.73 rear end true it helps with mpg but it really makes it hard for my car to get moving what is a good gear to put in so that I have good acceleration but not so low that I cant cruse at 70 or 80
Old Feb 25, 2013 | 01:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gearing
You could go with 3.08's with your current series II carrier, but that wouldn't help your situation much. If you go series III, I'd recommend 3.23's.
If you're unfamiliar with gears/rear ends, check the following FAQ.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 25, 2013 | 07:59 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Gearing
Allot of guys try to find a used rear end that has the parts they are looking for(gear ratio,posi.) and that usually is reasonably priced and that is why they do it that way. If you decide to rebuild it from scratch with new parts (expensive)check out post #38 in the link posted above.As it says the posi/locker (carrier) is totally up to you and they do make lockers that are less expensive than the Eaton Posi. and of course buying the support cover is totally a option.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
