Clutch Recomendation
Old Feb 28, 2013 | 11:48 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Looking for a clutch for my mild L98 TPI build. Daily Driver.
There are a lot of choices, Jegs has 12 different ones.
http://www.jegs.com/webapp/wcs/store...422+4294965982
Any preferances?
Old Feb 28, 2013 | 12:11 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: Clutch Recomendation
I'm a little partial to McLeod. They offer their street pro clutch. This kit comes with a pressure platem disc, T.O. Bearing and Pilot Bearing. Part Number you'll need is 75125
Old Feb 28, 2013 | 04:34 PM
David 91RS/Z28's Avatar
Lots of good choices and everyone will have there own experiences. Centerforce, SPEC, Ram, Mcleod have been around for some time and all have made great products. I sold many of the latter 3 brands years ago with great results and I've used a Centerforce DF in my car for sometime and have had great results. I've also seen bad experiences with all of them. There are good and bad experiences with all brands of clutch. Most of the time the bad isn't due to faulty clutch. There's lots going on with a clutch... the driver, functioning hydraulics, proper matching clutch to vehicle and modifications, gearing, daily driver or racer, etc. Just be sure to stick with something that is streetable. I'd go with the DF or the SPEC II for your setup.
Old Mar 1, 2013 | 08:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The Centerforce seems to be a good match for a mildy modified street/strip vehicle. They run less base pressure than some of the other high performance choices(so you're not heavy footing a high load clutch around town) and use centrifugal force to increase apply pressure under acceleration.
Old Mar 3, 2013 | 09:15 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
The only problem that ive heard with that (and heard it from Fortes parts connection in MA) is that at lower RPMs the centerforce does not have enough pressure and if it starts slipping down low in the rpms then it will just keep slipping. Behind a boosted motor that makes power up higher thats probably fine but most SBCs make a good amount of low end torque if they are built. I was thinking centerforce too but shyed away from it when i heard that argument.
I put a ram clutch in my car. I have a high compression 355 with aluminum heads that was engine dynoed with a carb at a tad over 400 hp. With TPI im sure its a tad less but maybe not? At any rate the ram has held up great. I was gentle to it for the first few hundred miles and then let it have it. It does have a heavier pedal feel than stock but my car is not a DD so i didnt mind. And ive felt a LOT heavier pedals than the ram as well.
Old Mar 3, 2013 | 04:22 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
i have a Centerforce Dual Friction. No complaints. It held up to my drag radials when the stock clutch wouldn't.
I'll never forget that first launch on those DR's with the stock clutch. i reved her up, let the clutch out, and i thought the tires were spinning and was very disappointed but then i smelled clutch instead of rubber. Stock clutch was still in good shape, but it wasn't strong enough for the DR's.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
