Shift up on automatic?
Old Mar 11, 2013 | 09:41 AM
1337xtcy's Avatar
Car: 92 t-top RS Heritage Edition
I have a 1992 RS with a 350. Whenever I hit about 50 in the car a shift up light comes on. I had a GM mechanic say that the steering colum is probably switched from a manual. But I aslso don't have the tachometer working so I don't know hos many rpms I am at. Does anyone know what the issue might be?
Old Mar 11, 2013 | 10:40 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Shift up on automatic?
if everything is working properly and the car isn't acting crazy because of it, take the bulb out from behind the cover, afaik all the thirdgens(at least the later ones) have the "shift up" lens in place, but if it was an automatic car a bulb was never installed(i don't even know if the wiring is in place to put a bulb in)
it almost sounds like that car was originally a 5 speed car, maybe when someone swapped the 350 they put in an auto tranny too
Old Mar 11, 2013 | 10:47 AM
1337xtcy's Avatar
The car has always been an automatic. I know the steering was swapped because my original starter is under the dash and I have the key I have a new turner. ( may not be proper but its extra security can't steal without both keys). But I don't know if if the rpms are normal when the light comes on. I don't think the rpm or the gas tach is in...
Old Mar 11, 2013 | 12:49 PM
Caveman305's Avatar
Engine: L03, LB9
was the gauge cluster swapped at the same time as the steering column, they are two separate pieces that merely bolt near each other, and have almost nothing to do with each other
if the cluster was swapped it may be hooked up wrong, pull it out and make sure everything is connected properly
you should also be able to tell if your car is over revving for the gear it should be in, try manually shifting through the auto gears and make sure it shifts every time you click it up one, if its shifting fine, pull the bulb
Old Mar 11, 2013 | 01:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just take the bulb out. It's not supposed to be installed on an automatic.
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
