Gear and trans swap
Old Mar 22, 2013 | 11:03 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Gear and trans swap
I have a 91 formula with a 700r4 and 2.73 and I’m swapping in an 85 t-5 and 3.73 700r4 with electric speedo installing t5 with manual speedo what do I need to make the speedo work and can I use anything form the 700r4 like the sensor or shaft gear? Thanks Tyler
Old Mar 23, 2013 | 07:49 PM
Engine: 5.8
Re: Gear and trans swap
so the t-5 has a blue drive gear in it can i just put a Electronic sensor and new gear in if so what driven gear do i need?
Old Mar 24, 2013 | 12:22 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
read my post. i literally just did this if you have questions pm me
Old Mar 24, 2013 | 02:08 AM
Engine: 5.8
You swapped the gauge cluster why would you do all that it is easier to put a sensor in the t-5 and plug it in I just need to put the right driven gear in.
Old Mar 24, 2013 | 10:40 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
yeah but i didnt spend any money swapping clusters i had it all there already. if i wanted to swap my t5 to an electric set up then i would have to spend more money and well being married i'm on a tight budget. anyway there are a plethera of gear drive calculators out there. and no you can't just put the electric setup in the tail shaft. you would need the entire tail shaft from a electric t5. the drive gears go on different. also why i swapped clusters
camaro11j
Sep 19, 2018 08:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
