T5 rebuild labor ?
T5 rebuild labor ?
I know some of you here could rebuild your own T5 but i am unsure if i am confident to do the same......So i was wondering what should i expect to pay (ballpark) for labor to have someone do it for me? Just labor is what i am looking for a quote, Not parts. I am most certain the box i have is a straightforward rebuild, No gear replacement. TIA
Re: T5 rebuild labor ?
If you can find somebody, figure on about 4 - 5 hrs @ $80/hr; something in the $300 - 350 (ish) range.
http://www.tremec.com/anexos/TRSM-T5-0510-R1_173.pdf
Read this and see what you think about doing it yourself.
Thanks for the info guys..... big gear head....It actually does not look too intimidating, But something about tackling it for the first time and wanting to get the car on the road asap might be pressuring me. I was looking at some how to books and cd`s on ebay that walk you through..hmmmm maybe
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
If you read over the instructions a few times from the link Big Gear Head posted and take your time, it's pretty straightforward. I did mine a couple years ago and it wasn't that hard. Took me about 5 hours or so. First time I ever took on a transmission rebuild too.
You will need a dial indicator or a depth micrometer, or something to measure the bearing preload. You will also need a press and bearing seperator to disassemble the main shaft. Getting the bearings off of the cluster gear can be a little hard, but if you are good at problem solving you will figure it out.
Car: 1992 Camaro RS
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
