700r4 wont engage
Old Mar 27, 2013 | 11:13 PM
littlevin91's Avatar
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
700r4 wont engage
i just finished a motor swap and i put a tci lock up in the trans i went to go test drive the car for the first time and when i put the car into drive and gave it gas the car didnt move an inch
Old Mar 27, 2013 | 11:22 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 700r4 wont engage
If the fluid is good and is full the next step is checking pressure with a gauge.
Old Mar 27, 2013 | 11:55 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Also make sure the tv cable is adjusted correctly at the carb/efi, and the shifter cable is adjusted properly at the trans linkage.
Old Mar 28, 2013 | 12:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have you confirmed the lever at the trans is actual in the D position ; not just that the shifter is showing D
Old Mar 28, 2013 | 12:57 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
im having the same exact problem
Old Mar 28, 2013 | 10:22 PM
Engine: 5.0 v8
the trans is full, there was no mounting bracket on the carb for the tv cable but we rigged it to work if it to tight would that cause the car to just rev, and the gear selecetors moving i was under the car and had some one go from park to 1
Old Mar 28, 2013 | 11:48 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
WHERE IS THE LEVEL ON THE DIPSTICK AT ? I HAD A SIMILAR PROBLEM ... MY PUMP FAILED. MY ATF LEVEL WAS EXTREMELY HIGH ON STICK. LOOKED LIKE A MASSIVE OVERFILL. THE PUMP WAS DEAD . ALL THE FLUID WAS IN THE PAN WITH ENG AT OP TEMP. AFTER ATTEMPTED TEST DRIVE.
Old Mar 28, 2013 | 11:50 PM
DRIVE2FAST's Avatar
DID U SET THE TV CABLE EXACTLY LIKE THE DIRECTIONS SAY?
Old Mar 29, 2013 | 05:22 PM
Engine: 5.0 v8
the fluid was alittle high on the dip stick but the car wasny at opperating temp and the tv cable therea no clip for it on the carb but we rigded it up to work so theres no play at wot
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
