Pointers on junkyard picking... Driveshaft and rear ends
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Looking to find a driveshaft (aluminum or steel) and a 9 bolt rear end.....maybe even a 10 bolt...at a junkyard
Can I have some pointers on what to look for when it comes to quality? I understand you never really know what you're buying until its actually tested but is there some things I can look for to have a good shot at success?
I know the big thing with driveshafts is looking for dents/bending... But it's not always very easy to see with the naked eye....
Rear ends, is there something to look for?
Is there a particular driveshaft for a 9 bolt ? Or 10 bolt? Does it matter ?
Chuck
Chuck
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Pointers on junkyard picking... Driveshaft and rear ends
The drive shaft is interchangeable between, say, all 85+ cars.
JamesC
Car: check
Engine: check
Transmission: check
Look for '90 - '92 V6 cars. Usually not enough HP to tear up the rear, and the ratios are nice.
The automatic cars have a 3.23 rear ratio. While the stick cars have the 3.42 ratio. Both have the larger 28 spline axles. Doubtful that you'll find one with a posi or disc brakes though.
And being that the cars are going on in the years, double check that the rear is what it should be. It may have been swapped at some point.
RBob.
RBob.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
