What does this switch do?
Old Apr 9, 2013 | 09:24 AM
nguilbea's Avatar
Car: 1992 Z28
Engine: 305TPI
I have 92 z28 w/ 700r4. It is all stock as far as I can tell except for a toggle switch mounted next to the shift. I have been unable to determine what the switch is doing. In one position the RPMs drop about 500 and all is fine as long as I am at highway speed. Driving in the city there is a hesitation or somewhat of a lurch (spongy feel) to the car while in lower gears. If I flip the switch when going slower the car runs fine and the RPM pick up slightly. Any ideas based on this description. I don't think there is a shift kit installed because it shift nice and easy even at WOT.
Old Apr 9, 2013 | 09:29 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: What does this switch do?
Sounds like its a manual torq converter clutch lockup switch.
Old Apr 9, 2013 | 10:15 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Aye. TCC switch.
Old Apr 12, 2013 | 08:25 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I would be more concerned that having it this way may do some damage.i would consult the trans shop of your choice on this subject
Old Apr 12, 2013 | 10:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is a very commonly done mod ; especially if the car has had the computer removed ( carb swap )
there are better ways of doing it ,see
https://www.thirdgen.org/forums/carb...c-control.html
but manual switch is not a problem so long as you remember to turn it off at low revs or before coming to a stop (engine will stall)
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
