94 caprice 700r4 in 82 camaro
Old Apr 15, 2013 | 08:54 AM
sportcoupe-z28's Avatar
Car: 82 Camaro SC
i found a 700r4 from a 94 caprice police car for cheap and was wondering how difficult it would be to install in my 82 camaro with a carb'd 355. what all will i need to get to install it? the car was setup for a manual tranny before.
so i basically just wanna know how to install a 700r4 in my camaro thats setup for a standard tranny and what all i need to get.
Old Apr 15, 2013 | 10:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 94 caprice 700r4 in 82 camaro
94 and newer cars and 93 and newer trucks are the 4L60-E, controlled by a trans. control module or a powertrain controlled module.
Older ones are the 700-R4 A.K.A. 4L60. The ECM controls torque converter lockup and that's it.
An aftermarket controller to run the trans. alone isn't cheap.
Old Apr 15, 2013 | 10:22 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
If the tranny you found is actually a 700R4 and not a 4L60E then you will need to make sure it has the correct tail housing with the 3 holes, needs the correct speedo setup if you want the speedo to work. You'll also need to set up the engine with the tv cable brackets (super important) and you'll need a flexplate and shifter and cable and crossmember. I'm not sure about the driveshaft.
Old Apr 15, 2013 | 06:24 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if tranny is 1994,it will be electronic control version as stated above and a lot more complicated to install than 1993-earlier non electronic version.I installed a 1985 caprice 700r4 in my originally manual '82 z28 using parts from 700r4 thirdgens and used a thirdgen tailhousing on the caprice tranny.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
blackd-out z28
Aug 15, 2015 08:18 PM
matthew911
Aug 12, 2015 09:38 AM
