Amsoil Tranny fluid.
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Howdy all. I am thinking of doing a tranny service on my IROC, and i would like put in Amsoil synthetic. Now i did run a search on their website, and it lists 2 flavors. But i am not sure. I think the spec calls for GM DEXRON II. But that is an old spec, and Amsoil covers the newer DEXRON III and IV. Also how much fluid will i need, for just a service? I am looking at about 10 pints? Thanks.
Re: Amsoil Tranny fluid.
If the oil looks and smells ok, leave it alone. Otherwise just use the oil you have been using for a service change. Amsoil is an excellent oil, but do a "complete" change if you are going to do this.
Car: 1988 IROC-Z
For some reason i just have it stuck in my head, that i need amsoil for all the fluids in my car. Maybe i just do the rear-end for now. When i get her in the shop, for 2 new tires, i think i will just have them check the tranny fluid.
After all, Amsoil is not cheap!
Car: `86 SS / `87 SS
Drop the pan and change the fluid and filter every 20,000 miles.
That's a lot more important than changing to synthetic.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
