best fluid for 9 bolts
Old Apr 17, 2013 | 10:02 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what should I use in my 9 bolt?
thanks
Old Apr 17, 2013 | 11:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: best fluid for 9 bolts
I've just been through this. If you do some searches you'll find many threads with many opinions and suggestions. I ended up just putting in what the store had. CRC Sta-Lube 80W90 with no additive. So far seems to work just fine.
Old Apr 17, 2013 | 02:24 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah the only thing I can determine is it's probably best to NOT put additive in it. The additive helps lubricate clutches on clutch style LSD's so that they dont make noise. GM changed its mind on putting additives in the 9-bolt during the middle of hte production run, so I assume they changed their mind for a reason. So I just use whatever.
Old Apr 17, 2013 | 05:53 PM
jamon8's Avatar
Engine: 350 tpi
thanks guys 80-90 it is without posi additive
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
