85 TH700 torque converter question
Old Apr 30, 2013 | 10:20 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
I just bought a used trans and it has a B&M torque converter. Im having big problem trying to figure out what type of converter it is, stall speed. I found a stamped number 90077-L and a sticker 8653166 then next to it on same sticker but sideways DE6Y. I call B&M and they said there isnt any identifiers on the torque converter!? So essentially, according to B&M you wont know what you have unless you buy a new one? REALLY?! Is there anyone that might know something "they" dont? I just find it hard to believe! Any help PLEASE
Old Apr 30, 2013 | 12:34 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: 85 TH700 torque converter question
taken from:
http://www.hotrodders.com/forum/how-...er-172228.html
Is the converter in a running drivable vehicle? If so you can check it.
A "stall test" can be used on many transmissions, if you use this procedure, do not do it for more than five seconds at a time.
Before conducting a stall test, check the fluid level and condition. Chock the wheels and set the parking brake. Start the engine and place the transmission in drive while holding the brake pedal under firm pressure so the vehicle doesn't move. Then push the accelerator to the floor while holding the brakes on. Note the maximum rpm that the engine reaches.
That's the only way you'll know for sure. Unless the guy you bought it from knows. . (which he probably should...)
Old Apr 30, 2013 | 12:38 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Originally Posted by Keoman
taken from:
Not in the car yet, and kinda wanted to know before in case i wanted a different one. You would think the guy would know, but doesnt, he was selling for a friend.....long story!! I just cant believe B&M didnt put any identifiers on it!??!
Old Apr 30, 2013 | 12:43 PM
Keoman's Avatar
Your the expert, guess not.
Like i said, only way is to have it in a running car.
Old Apr 30, 2013 | 01:03 PM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Where did i say i was the "expert"? If i were, i wouldnt be here asking questions, but thanks?
Old Apr 30, 2013 | 11:00 PM
morgsie's Avatar
Yet another reason not to run B&M junk.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
