1984 and 1992 Manual Trans compatability....
Old May 9, 2013 | 05:02 PM
trinkits's Avatar
I have a 1984 z28 5 liter HO. Its a factory automatic and i am converting to 5 speed. Found a complete parts setup form someone but its from a 1992 Camaro and the box is a WC. Will this swap right in as would a non WC T5 from an earlier third gen?
Old May 9, 2013 | 05:51 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: 1984 and 1992 Manual Trans compatability....
https://www.thirdgen.org/forums/tran...lp-vss-t5.html
That should answer your question; you will run into the same cable driven to VSS speedo issue.
Old May 9, 2013 | 06:21 PM
trinkits's Avatar
thanks!
Old May 9, 2013 | 06:49 PM
trinkits's Avatar
Will everything else from this 92 be compatible if i use an earlier T5? such as bellhousing. clutch fork, crossmember ?
Old May 10, 2013 | 09:23 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Everything should be the same. I just swapped a WC into my 84 with no issues.
Do your self a favor and get a good shifter and dont miss third. Also while you have the trans out I would suggest buying a STEEL cluster support plate.
Old May 10, 2013 | 10:28 AM
trinkits's Avatar
thanks!
Old May 12, 2013 | 09:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Will everything else from this 92 be compatible?
You need a flywheel to suit your early 2 pce RMS engine.
The flywheel from the 1 pce RMS '92 won't bolt up to your crankshaft
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
