T56 Clutch ?
Old May 12, 2013 | 11:19 AM
johnod's Avatar
Car: A little OT, with Camaro drivetrain
Axle/Gears: 4:11s
T56 Clutch ?
I found a lot of good info here when i installed my LT1 T56, and now i've got another question.
I experienced the usual high clutch pedal thing but just dealt with it.
Now however I have a rattle sound when pedal is fully depressed, it dissappears when clutch is released, clutch seems to work fine tho.
I think i'm going to have to remove trans etc to see what the problem is.
Reading some of the threads here I've read that fourth gen pedals will cure the high clutch, also read that a Tick Master will solve problem.
http://www.tickperformance.com/tick-...or-lt1-f-body/
Anyone used either? Can you tell me how it worked out, especially the Tick unit.
Also i read there is a fix for the third gen pedals somewhere here, but can't seem to find it, can someone point that out for me.
Thanks for any help you can oiffer
Old May 12, 2013 | 11:56 AM
87350IROC's Avatar
Car: 87' IROC
Re: T56 Clutch ?
I use the tick master. The pedal can be adjusted to remove any free range from the pedal throw. The tick master is a larger bore than OEM so the pedal will be very short and very firm. Whether or not that is good, is your call.
John
Old May 12, 2013 | 12:02 PM
johnod's Avatar
Axle/Gears: 4:11s
Re: T56 Clutch ?
John
How does it hook up to the (stock?)slave?
Old May 12, 2013 | 12:24 PM
87350IROC's Avatar
Car: 87' IROC
Re: T56 Clutch ?
I use the stock fourth gen slave. The master comes with a hose that fits.
Old May 12, 2013 | 01:45 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: T56 Clutch ?
Your clutch has too much travel and the pressure plate is hitting the clutch fork when the pedal is fully depressed. The Tick master will fix the problem or a cheaper solution is to use a late '80's Cavalier slave cylinder. It has a larger bore which reduces the travel. I have a few extra of the slaves if you want a new one for $25 shipped. Another benefit of the Cavalier slave is it has a bleeder built in.
Old May 12, 2013 | 01:56 PM
johnod's Avatar
Axle/Gears: 4:11s
Re: T56 Clutch ?
If that works, and you can ship quickly, I'll take one, PM me your paypal info.
Need any special fittings or tools to connect the two, is it bolt on to stock LT1 bellhousing?
Old May 12, 2013 | 02:02 PM
87350IROC's Avatar
Car: 87' IROC
Re: T56 Clutch ?
You need to figure out what you want. The caviler slave will work but with a longer and softer pedal feel. Is that what you want?
Old May 12, 2013 | 02:14 PM
johnod's Avatar
Axle/Gears: 4:11s
Re: T56 Clutch ?
Softer is fine. As long as it will lift the Pressure plate.
Can you give me details on longer please?
Now it just engages at the last 2 inches of the top of pedal throw.
I don't want to have to depress clutch carefully all the way to the floor to shift, when driving. But would like to shift sort of normally.
If by longer you mean the clutch starts to engage sooner ( from a stop)than the last few inches that would be fine.
Old May 12, 2013 | 03:05 PM
87350IROC's Avatar
Car: 87' IROC
Re: T56 Clutch ?
Softer means less leg effort will be required.
Longer means the distance the pedal travels through the engagement zone will be longer. It is the distance from non engaged at all to fully engaged.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
