Help with rear end swap
Im new to having a third gen Camaro and I found a nice 92 Z28 with a 5.7 TPI. Well I thought the car had the stock rear end that was a 3.23 so I bought a new rear end to put in the car it is a 410 posi. Well come to find out the rear end was swapped out with a 4th gen rear end and not sure what it is. Is there a reason why someone would have installed a 4th gen in is it better then the third gen. And if so why is it better they both had disc brake set up. So I hope someone can tell me why a 4th gen rear end maybe better than the third gen thanks for any help.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Help with rear end swap
Better brakes, maybe better gears, newer posi.
Allows the use of 4th gen style wheels.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Strength wise, it's the same diff but slightly wider. Normally they're swapped over for a better brake system.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
