t-5 swap reverse light hook up ??
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
I swapped a 86 firebird t-5 into my 92 Camaro and I wanted to know, is the reverse light pigtail in the car somewhere, like the clutch neutral switch wires where? or do I splice into the safety neutral switch harness from the auto?
Re: t-5 swap reverse light hook up ??
If your car was originally auto, then no, there is no reverse light pigtail
Source a loose pigtail and splice it into the old auto shifter connector. Middle two wires, can be reversed with no issue
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Like he said, get a two pin connector, use the puple and green wires friom the auto sw. and plug it into the trans...bingo reverse lights.
