B&M Megashifter Relay/wiring bypass question
Old Jun 2, 2013 | 11:07 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I got a problem (dont we all do).
Im installing a Megashifter. Everthing goes smooth until I crank my IROC. Once I crank the engine, the small white wire in the relay burns out just like a fusible link. This wire is the bridge for the heavy gauge Purple and Yellow wires. The Yellow wire has a 12 volt charge coming from the ignition switch when turned to "Start". The Purple wire goes to the starter. Its obvious to me that this thin wire is not handling the amount of current that is flowing across it. Has anyone had this issue? If so, how did you solve it? The relay is the one that B&M recommends
Old Jun 2, 2013 | 11:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: B&M Megashifter Relay/wiring bypass question
If you wire the yellow to purple the car would start in gear. Is this using a micro switch to control the relay trigger side ?
Old Jun 2, 2013 | 11:19 PM
Yeah. I was thinnking of installing a 4 pin relay between the P/N ECM lead so that once the micro switch recieves current, itll activate a seperate relay that'll handle the higher current. What do you think?
Old Jun 2, 2013 | 11:20 PM
I wanna do it right, but this damn thin wire keeps burning out on me.
Old Jun 2, 2013 | 11:27 PM
Engine: Lb9
Transmission: M20
Yeh just use a Bosch 5 wire relay. I have more than a dozen of them and pigtails for sale
Old Jun 2, 2013 | 11:29 PM
Okay. Ima have to do some homework and a bit of photoshopping. Thanks B.
Old Jun 2, 2013 | 11:44 PM
Engine: Lb9
Transmission: M20
http://www.shoptalkforums.com/viewtopic.php?t=125748
In the schematic instead of the ign switch it would be the momentary switch.
But if you wire the park neutral switch to the micro switch and the relay is hot on the trigger side but the micro switch is connecting the path to ground that would solve your issue.
Old Jun 3, 2013 | 12:11 AM
Engine: Lb9
Transmission: M20
Old Jun 3, 2013 | 12:27 AM
What about this one?
Old Jun 3, 2013 | 12:34 AM
Engine: Lb9
Transmission: M20
Look at this schematic, the p/n gets grounded
http://www.gearhead-efi.com/Fuel-Inj...8&d=1331257304
Old Jun 3, 2013 | 12:41 AM
Which micro switch needs to be on 86? Or is my diagram good?
Old Jun 3, 2013 | 08:08 AM
Engine: Lb9
Transmission: M20
Call me today for tech support lol
Old Jun 3, 2013 | 11:19 PM
Problem solved. I de-soldered the remaining burnt wires with some de-soldering braid and soldered in a thicker gauge wire. Camaro fired up real quick. Next project, install the B&M shifter. If anyone needs this modification done, let me know. I can guide you or help you out.
Old Sep 26, 2013 | 05:45 PM
Engine: Lb9
Transmission: M20
Two ways to wire the reverse lights one is light blue to one side of the micro switch and light green on the other.
Or a better way of doing it is to use a second relay.
Ground 85 to the chassis
Wire the blue wire to 86
Wire the green wire to 87
And have a fused power to 30
Old Sep 26, 2013 | 05:50 PM
Brian!! I thought this thread was dead. Heck,, I forgot all about it.
Old Sep 26, 2013 | 05:57 PM
Engine: Lb9
Transmission: M20
I knew it would make you come out of the wood work lol, I posted it for a member that pmd me
Old Sep 26, 2013 | 06:07 PM
Haha. I'm out. I'm actually freaking out. I'm working on a laptop as we speak. I updated the bios and the laptop didn't like that. I pretty much made the laptop a brick. Not cool man.
Old Sep 26, 2013 | 06:33 PM
Engine: Lb9
Transmission: M20
Uhhh that sucks
Glowsock
Jul 24, 2025 03:15 PM
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
