TH350 torque tube to trans mounting bracket for Camaro / Trans-Am
Old Jun 9, 2013 | 08:13 AM
Gambit TA's Avatar
Car: 1982 Trans-Am Stroker 388
Engine: Chevy 350 four bolt Stroker 383+60
Transmission: Tremec T56 6 Speed
Axle/Gears: 4.56-1 posi
Wanted, Hi Guy's I am looking for a TH350 torque tube mounting bracket if possible. I have a TH200c at the moment and need the TH350 bracket to fit my new trans. Thanks Paul Wales UK
Old Jun 10, 2013 | 09:29 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: TH350 torque tube to trans mounting bracket for Camaro / Trans-Am
do a search on summitracing.com, jegs, a few others for torque arm relocation bracket or th350 conversion cross-member
you have a few options as far as what you want to do with it. i think spohn makes one too but it expensive. but you get a driveshaft loop, adjustable torque arm, and mounts for the th350 all in the same unit
Old Jun 10, 2013 | 12:34 PM
Gambit TA's Avatar
OK thank you for all the information, Im in the UK and we do not have any of those shop's over here. I thought that there may be a bracket that I could get off the shelf, but it is all after market and in the US I will have to find a way to get hold of one from the US
Old Jun 10, 2013 | 03:16 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
yep, there was never a th350 in a third gen so everything is aftermarket. if you are good at fab you can make one with your old one and your old crossmember, but it requires some welding and drilling
Old Jun 11, 2013 | 11:24 AM
Gambit TA's Avatar
I got you, thank you for all your help and I think I will be saving up for one. the shipping and tax will be a nightmare for me over here .
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
