LS1 T56 on SBC 350?
Old Mar 23, 2010 | 11:23 PM
VandykeT/A's Avatar
LS1 T56 on SBC 350?
Ok a friend of mine can get a 6 speed out a LS1 car and hes wondering if its possible to use this with a SBC and if so what would need to be changed to make it work.
Old Mar 24, 2010 | 06:17 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: LS1 T56 on SBC 350?
Either get an adapter plate and run it with a Muncie/T5/T10 clutch/bell setup
http://www.thegearbox.org/catalog/it...17/4803441.htm
Or swap over the bellhousing/mid-plate/input-shaft from an LT1 T56 and mount it directly. Would use LT1 clutch setup and either a stock LT1 or conversion flywheel depending on RMS
Old Jun 11, 2013 | 02:29 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Transmission: muncie m22
Axle/Gears: 10 bolt limited slip 373's
Hey about that adapter plate...I see you would use the same bell housing clutch and clutch linkage for your muncie setup....so does that mean you use the same flywheel also from your old set up
Eric-86sc
Aug 24, 2015 09:01 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
