clutch pedal
clutch pedal
hello I have a 1987 Camaro that I cant get the slave cylinder hook up to the pedal with out bending the rod the car was auto trying to make it Manuel I cut 3 holes still will not line up to the pedal I got the pedals out of a 1989 camaro I think they are the same as 87 camaro any help please thanks mike
Car: `86 SS / `87 SS
Re: clutch pedal
Loosen the nuts retaining the master cylinder. You'll then have more freedome in the range of motion.
Re: clutch pedal
Yes the pedals are the same.
Don't try to hook the pedal to the slave cyl; hook it to the master cyl instead.
Sounds like you cut the holes in the wrong place. Might need to move em over.
