t5 swap no clutch resistance
So I swapped in a 89 camaro t5 using 153 bellhousing and clutch, flywheel, and throw out bearing from the Camaro into my 1970 Nova.
The car is still on jacks in my garage but I have fully hooked up the clutch. Aka pushrod, and spring, its mechanical. There is no ATF fluid in transmission and drive shaft is still not installed.
When depressing the clutch there is zero resistance. Any reason for this issue?
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: t5 swap no clutch resistance
might be dumb question but did you fill clutch master cylinder up with fluids and theres no leak
rsrmoore
Aug 7, 2015 08:44 PM
