t-5 to t-56 swap
Old Jun 30, 2013 | 07:26 AM
fastlam12's Avatar
t-5 to t-56 swap
I've searched the forum for info but I still have few questions. I have an 86 TA with a 1st gen sbc and a t-5. My question is if I use the lt1 bell and a hyd throwout bearing can I retain my current clutch ? and will my stock clutch master cyl work with a htob ?
Old Jun 30, 2013 | 10:55 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t-5 to t-56 swap
Yes it can but I don't know of one that fits depth-wise. The selection is smaller because of the unique throwout bearing sleeve diameter of the LT1 T56.
The McLeod first design for this (released over 10 years ago) was too thick and required more distance between the trans. and engine. Based on the current web page for the newer design, I believe this may still be the case.
Ram (see thread below) indicates theirs needs more distance between the trans. and engine.
That impacts shifter position and driveshaft length. So it ends up being more straight forward to buy the flywheel, keep your stock driveshaft and have only 1 aftermarket parts that might need serviced.
This thread has a bit of information but it's not the only one:
https://www.thirdgen.org/forums/tran...-flywheel.html
Master cylinder bore (3/4" for third gen) & travel are what matters for a TOB.
Old Jun 30, 2013 | 11:13 AM
fastlam12's Avatar
will my clutch work or do I need one for an lt1 ?
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
