nwc t5 help
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
nwc t5 help
ok so the tags on the t5 say its a 1986 firebird trans, 2nd gear was hard going into, plus it was leaking, and the bearing were shot so im in the middle of a rebuild till I saw these, and now I need some answers. (ignore the "rust" spots, its from the water when I cleaned them off, ill be rubbing those away with carb cleaner b4 reassembly)
ugh gona have to muti post the images so bare with it.
1st image is of case cover off
2nd is of main case (empty) looks good but has nicks at some opening, thinking just sand them a little and good?
3rd is the tail housing, not sure if you can see them but the bottom appears to have a bunch of cracks (or stress marks) but none of them go though the case. so is it usable still?
Engine: 305 tbi
Re: nwc t5 help
these are the gears, no idea which ones are which >.> but anywas if you can see all the gears "upper" teeth are rounded, is that normal and reuseable? (the teeth on the top of the gears, the smaller set)
also in the 1st picture anyone know what those gears are with the straight teeth? they both have chips missing and need replacement.
Engine: 305 tbi
Re: nwc t5 help
scyro rings I believe these are, if you can see the tips of the teeth are also rounded, both sides, but one side looks smooth like it came that way but the other side looks rough.
Car: `86 SS / `87 SS
Re: nwc t5 help
post #3, first picture, top slider ring, replace that; the others are cool.
Re: nwc t5 help
post #2, first picture, top slider ring, take a better picture.
post #2, first picture, right hand straight cut gear is the reverse idler gear. I have a new one, PM me if you need it. http://www.thegearbox.org/catalog/it...32/3532149.htm
Re: nwc t5 help
They all look completely fine to me.
Worst thing I see really, is the reverse gear; looks like some numbskull n00b didn't put it into a forward gear before reverse ALOT, and instead just jammed it in while grinding; pretty typical unfortunately. But not beyond re-use.
All the shifting teeth on the gears and on the inside of the sleeves look fine.
Didn't see any of the blocker rings (what people usually call "synchros"); they're brass. But from the looks of the rest of it they're OK too. In fact I've only had to replace those once or maybe twice. Yours are probably OK.
The features in the casting are a non-issue.
The ONE THING I'd be looking at the most, if that was mine, is how the clutch gear and countergear teeth meshed.
Engine: 305 tbi
Re: nwc t5 help
I pmd u jmd and ill get a better pic.
sofakingdom I have a master rebuild kit so I have new synchros/blockers but you are right they didn't look bad at all. ill check the teeth bc it was hard going into 2nd, and only 2nd.
btw im that numbskull n00b >.> would usally just go from what ever gear I was in, or neutral, into reverse. never grinded went in smooth every time. I have learned the proper way tho but the damage appearently was done.
Re: nwc t5 help
Hey, we're all born not knowing stuff like that; it's important to keep on learning as we go, and not make the same mistakes over and over.
Glad you got it figured out.
Glad you got it figured out. Thread Starter
Engine: 305 tbi
Re: nwc t5 help
ok so other then reverse gear should I replace anything else? money is getting really tight fast , but if I must replace something I will.
btw since the syncho looked fine for 2nd gear, ideas on why is was hard to shift into only 2nd gear?
and finally (so id ont tear up reverse anymore) I go from 1st to reverse? or how am I suppose to go into reverse
Re: nwc t5 help
Engine: 305 tbi
Re: nwc t5 help
ya the kit I have has those, came with plastic inserts tho :/
clutch is new, about 1k miles on it. has been wearing even and everything is as tight as it should be. same for the pressure plate.
the trans has never ever grind and its only 2nd gear. not 1st not 3rd not even reverse, only 2nd gear. does not pop out shifts out smooth. shifts smooth into every other gear but you have to "slam" the shifter into 2nd to make it shift, moving or standing still. why im puzzled by it. if it wasn't apart I would show you.
ok I understand the shifting into reverse now.
88GTA3555SPD
Feb 8, 2006 09:40 AM
Pablo
May 18, 2005 05:03 PM
