91 700r4 1-2 shift valve
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
Alright trans is doing good had an issue with my 1-2 shift tore vb off and sure enough the one piece sleeve is loose in the vb. In essence I could just JB Weld the end of it to the valve body correct? I have looked everywhere for a replacement sleeve to no avail.
Re: 91 700r4 1-2 shift valve
No second gear still! Tv cable adjusted, governor good now I must remove the pan again and check my governor screen. I will also check my band anchor pin too. Anything I,m missing? It had second gear, time for a reman valve body?
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
