700R4 with shift kit
Old Jul 18, 2013 | 04:06 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
I have a 1987 Camaro when stock had the carbed 305 with auto 700R4 trans. I got a deal on a 350 with approx 310 rwhp and 700R4 trans that I could not pass up. The ? I have is, What gears does a shift kit effect the shifting in, what difference does a vette servo make over the stock servo, the trans also has a 2500 stahl converter in it.The trans seems to really shift hard into second gear and than a little firmer into the rest. By hard I mean it wants to break the tire's loose at part throttle. What does the T.V. cable control and what is the best way to adjust it. I installed a Hurst Dual Gate shifter that is made for our cars, I also upgraded to a 9 bolt rear with 3:70 gears. Does this sound normal for this set up? Any comments would be appreciated. I have learned so much from you guys.
THANKS
Old Jul 18, 2013 | 07:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700R4 with shift kit
Read
http://www.cpttransmission.com/tech_tvcable.htm
to understand what it does
You don't. You SET it in the correct position like this
http://sethirdgen.org/tvcable.htm
Usually all because it increases the pressure so all shifts are faster and firmer.How hard will depend on the kit used
Quicker / firmer shifts
http://67-72chevytrucks.com/vboard/s...d.php?t=381813
Old Jul 18, 2013 | 08:39 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Originally Posted by vetteoz
Read
Thank you so much for the great info.
Old Jul 18, 2013 | 08:45 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Don't forget the venerable http://www.tvmadeez.com/
Old Jul 19, 2013 | 07:00 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Another ? I have is, this motor was a TBI and I switched it to carb. My original motor was a 305 carbed with the 700R4, I noticed a difference in length of the TV cables, the TBI cable was longer, so I put my original carbed TV cable on the 350 & trans combo, was this a mistake?
Old Jul 19, 2013 | 02:43 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
I want to thank you both far all the Great information. What a difference a properly adjusted TV cable makes. I had to adjust it a few time's, each time I adjusted it I would mark it and then go for a test drive, after about the 3rd time everything was much better. I think I will get a pressure guage and and use this as a secondary check.
Again, Thank You
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
