700R4 spins tires in park, engine dies in gear.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'm working on a 1988 Trans am, Its a 305 TBI car with a 700R4.
What i know: When the car is in park and you start the engine the entire car leaps forward for a split second but doesn't go anywhere, put the car in any gear the car dies but now with the rear end suspended on jack stands with the tires off the ground when the car is in park when the engines running the tires spin at a consistent speed, selecting forward and reverse gears is fine when the cars rear end is suspended however when applying the brake when in forward or reverse gear the car bogs down and when more brake pressure is applied the car dies instantaneously. I have hooked up to the ALDL and i have flagged data (I'm using WinALDL as my logger) In the flagged data the boxes checked are: p/s pressure switch, No high gear, Park/Neutral, Old high gear.
I'm not as knowledgeable when it comes to automatic transmissions so any help would be appreciated!
Re: 700R4 spins tires in park, engine dies in gear.
Anyway to test or fix this?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
700R4 works or they don't, when they don't, it cost money.
There is never any inbetween with them. Drop a grand on a new one.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pull the elec plug out of the drv side of trans and see if it still happens
However if the trans is functioning correctly and the convertor was locked it should only stall the engine when in gear ( on the ground )
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Kinda' sounds like the lock-up is always engaged.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I think this transmission has more than a few issues going on.
I looked into it more today, 1st the cable is broke and you can move it in gear by hand under the car. 2nd the MAP sensor was connected to a one way check valve and was consistently under MAX vacuum i think this was part of the why it would die in gear... I push the tranny in park by hand, started the car, no tire spin. I'm going to order up a new cable and see what happens in the other gears.
