Odometer Not Working
Car: '89 Formula
Engine: L98 350
I've got an '89 Formula and the odometer and tripometer are not working. Just had the engine rebuilt. The car is new to me and I don't know if it was working before the engine was rebuilt or not. Just talked to Hamp's Speedometer and was told they couldn't repair the odometer due to how the plastic gears were attached. Assuming that the problem is not in the speedo cluster itself, is there anywhere else to look for a potential problem? I have know idea how the odometer works. Maybe something isn't connected somewhere.
Just an FYI, the speedo itself works fine as do all the other gauges.
Thanks,
Chris
Thanks,
Chris
Car: `86 SS / `87 SS
Re: Odometer Not Working
it's an electric speedo, so there may be a broken electrical connection for the odometer.
they're a pretty easy speedo to take apart, all things considered and a used one for parts isn't tough to come by either.
Jump right in.
Jump right in.
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Thanks,
Chris
Thanks,
Chris
So I assume the problem lies in the speedo cluster.
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
I had an issue where mine didn't work above 55 mph. I took it out and couldn't find anything majorly wrong so I just put it back in and it worked! I'm assuming it was just a loose connection. So worse case scenario, it's worth taking it out at least to identify a problem.
Car: '89 Formula
Engine: L98 350
Good point Ransford. That's what I was planning to do. Are you aware of a good "How to" to remove the speedo? I've done some some searching and hadn't found anything really specific on how to do it.
Thanks,
Thanks,
Engine: 5.7 TPI
I've never taken a firebird gauge cluster apart, so I can't say for sure. I'm betting that if you take the front plastic cover or gauge surround off, you should see the clear plastic cover. Remove that and it should be fairly simple to remove the gauge(s). this video is useless as far as steps go, but it might show you what you are looking for as far as screw/clip location, etc.
Terrell351
Jun 13, 2021 01:13 PM
