summits ring and pinion set :(
Old Aug 13, 2013 | 10:10 PM
warrior102's Avatar
Car: 1986 camaro sport
Engine: 5.0 vin# H
Transmission: t-56
Axle/Gears: 3.73 possi disc
About 3 years ago I put in this set of 3.73 gears from summit I set them up perfect put they were still Ia little but noisy I figured it was just because of the higher ratio until the he other day when I shifted into second at about 4000 and all of a sudden the car sounded like the jetsons mobile good thing I held on to my 2.73s when I pulled the cover off to begin swapping them out this is what I saw ...are these just weak or did I do some thing wrong
Attached Thumbnails summits ring and pinion set :(-20130813_180009.jpg   summits ring and pinion set :(-20130813_180039.jpg
Old Aug 13, 2013 | 11:09 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: summits ring and pinion set :(
If you set lash correctly then there is no reason it shouldn't have gone 100,000 miles like your OE gears.
Had to be a manufacturing defect of some kind.
To avoid this what I plan to do is get a set of used GM "take off" gears.
I am sure you could find a set of original GM take off gears on ebay for cheap.
Old Aug 13, 2013 | 11:32 PM
warrior102's Avatar
Engine: 5.0 vin# H
Transmission: t-56
I put my 2.73s back in for now and I plan on ordering a set of strange gears and an eaton diff maybe go with moser axles
Old Aug 14, 2013 | 07:01 AM
big gear head's Avatar
You paid for cheap gears and that is what you got. Quality doesn't cost that much much more at the time of purchase, but it sure pays off in the long run.
Old Aug 14, 2013 | 07:45 AM
warrior102's Avatar
Engine: 5.0 vin# H
Transmission: t-56
Your right about that but when I bought the gears some one told me that richmond made the gears for summit ......not so much lol
Old Aug 14, 2013 | 12:14 PM
Richmond might have made them for Summit, but they made them as cheap as possible. Probably short cycled the heat treat process and some of the lapping. Also probably made them from a cheaper metal.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
TreDeClaw
Aug 14, 2015 06:58 PM
