speedometer cable replacement - question
Old Aug 16, 2013 | 07:52 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Car is 1988 Camaro V6 with manual transmission.
Pitch of the sound coming from the existing cable waxes and wanes with speed of car.
Severity seems to be random. Sometimes hardly notice it. Other times a mild "chirping." Other times it sounds like a rooster with his nuts caught in a blender.
New cable is on the way from Summit.
Any pitfalls I should be aware of in replacing the old cable?
Just pop the old one out of the back of the instrument cluster, and out of the transmission, and plug-in the new one?
Any special tricks to this "just pop it out" method?
Any thoughts on lubrication of the new cable from Summit?
Should I expect it to arrive in "dry" condition?
Old Aug 16, 2013 | 08:30 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: speedometer cable replacement - question
Be cautious when inserting the new cable into the trans. You don't want to pierce or tear the little seal in there.
Old Aug 16, 2013 | 09:04 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I had the hardest time getting up there under dash etc to disconnect speedo cable from back of cluster, take your time/patience etc. I took out driver seat so I get a better position to see from underneath dash & had shop light as well. PITA for me, best wishes on your project
Old Aug 16, 2013 | 02:48 PM
W.E.G.'s Avatar
Engine: V6 2.8
I already have the dash pad removed and everything exposed to get at the fasteners for the cluster. Frankly the interior of the car is pretty much "stripped" except for the bare minimum accoutrements needed to drive the car legally. I've been driving it in that condition on-and-off.
Its like my daily demolition-derby driver.
Big trucks move out of my way when I appear in front of them.
I kid you not.
A good fella at a friend's shop has been trying to chase down the water leaks at the firewall and cowl. Seems like every time one gets plugged another rears its head. Until we can get that sorted for sure, the dash pad, dash fascia, and all consoles and carpets are gonna sit in the basement.
We're "going back in" after more firewall leaks probably just after Labor Day.
I'm hoping the good fella won't mind doing the speedo cable at the same time.
Getting behind the gauge cluster is going to be simple.
I'm wondering how "tricky" it is to handle the OTHER end of the cable.
Old Aug 16, 2013 | 03:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by W.E.G.
Pitch of the sound coming from the existing cable waxes and wanes with speed of car. Severity seems to be random. Sometimes hardly notice it. Other times a mild "chirping." Other times it sounds like a rooster with his nuts caught in a blender.
The issue sounds common. Cleaning and relubing would probably solved the problem. Info below:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Aug 17, 2013 | 05:59 AM
W.E.G.'s Avatar
Engine: V6 2.8
Thanks James.
Will the inner cable slide out of the outer sheath without disconnecting the outer sheath from the tranny?
It would be nice to pull the inner cable out and inspect/lube (replace?) it before committing to having the body-shop guys start wrenching on the tranny, and trying to route a new sheath which will have to "learn" the bends down to the tranny.
Old Aug 17, 2013 | 06:16 AM
JamesC's Avatar
Yes, but to clean the sheath, you'll need to unhook the lower end of the cable from the trans. Not a big issue.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
