Bearing?
Old Aug 18, 2013 | 02:01 PM
Prodigy94's Avatar
Car: 84 Camaro H.O Z28
Engine: 305 L69
Transmission: 5 speed
Bearing?
Hey guys I have some questions,, my completely stock third gen 84 z28 makes noise almost like a cricket . I believe is my throw out bearing . At all times when the car is on the noise is there without touching the clutch pedal, but as soon as I put pressure on the pedal it stops. The rmps can be at idle or at highway speed and the noise is there. I just want to make sure which bearing it is . I plan to fix the problem myself I would appreciate some pointers, advise, and suggestions. How long would it take and how complicated could it be?? Thanks
Old Aug 18, 2013 | 11:18 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Bearing?
its your throw out bearing and if you have the mechanical linkage you need to find a way to load the fork pressure so it will stop. if tour system is hyd (being 84 I doubt it) you need to bleed the system a time or few.
never had the issue on my 83 T/A but have had this issue on my 89 FORMULA.
Old Aug 19, 2013 | 05:54 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Bearing?
Throwout bearing.
A few hours.
Tools and a trans. jack for most folks.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
