Ring and Pinion Help
Old Aug 18, 2013 | 03:38 PM
Camaro199677's Avatar
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
I just picked up a used ring and pinion from a friend. It came out of a 7.5 78 el camino. I have a 85 camaro z28. The Ring is stamped with Richmond 80-0358-1 and the pinion is stamped with 80-0359-1. They are 3.73s
I'm wondering if this will fit in my rear end and what series carrier it uses because I do plan on buying a posi unit. I have a peg leg right now. Thanks
Old Aug 18, 2013 | 08:17 PM
big gear head's Avatar
Re: Ring and Pinion Help
If your Camaro has the 7.5 rear end then it will fit. I can't tell you what series differential it fits. You might check the Richmond web sight or just do a google search with that number and see what comes up.
Old Aug 19, 2013 | 09:19 AM
Thank you. I did a google search and all that came up was other people asking the same question I am on the ls1 forum haha. I guess I'll just call richmond and see if they can help
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
gord327
Sep 29, 2015 10:18 PM
