Early Shifting/TV Issue?
Old Aug 20, 2013 | 08:46 AM
joem84's Avatar
Car: 84 2.8v6 and 84Z 350
Engine: 2.8 V6 and 350 crate motor
Working on my newly purchased 84Z 350 w/700R4 trans, when I take off quick going full throttle, the car shifts smooth but goes from 1-2 at 3600 RMPS, then from 2-3 at 2600RMPS, not ideal for 0-60 time.... I'm going to reset the TV Cable this afternoon, hoping that will help but curious as to what other folks have experienced. Transmission is great, not issues at all, just isn't very fast as is, not really taking advantage of the power available. I don't want to make anything worse, from what I've read, you just reset the TV adjustment and rotate the throttle to WOT and it sets itself. Is there anything else I should check or look for?
Thanks,
Joe
Old Aug 20, 2013 | 02:22 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Early Shifting/TV Issue?
a shift kit and 3.42 gears on a eaton posi should cure that for you nicely
Old Aug 20, 2013 | 05:05 PM
joem84's Avatar
Reset the tv, helped a great deal...... May look into a torque converter and new rear end at some point.....that will be further down the line though unless something falls into my lap
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
