quick quest. about vss
Old Sep 4, 2013 | 11:24 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
hey is it possible to take a 3.1v6 engine and auto tranny and vss (electronic speedo) out of a 91rs and drop in a 357v8 with 700r4 tranny with a speed cable speedo? and how to make the speedo work?
Old Sep 4, 2013 | 05:11 PM
Car: 91RS
Re: quick quest. about vss
I guess what I can do is exchange the speedo mechanisms from one to the other
Old Sep 4, 2013 | 09:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you have a carb you only need the VSS signal for the speedo
But you need to check how the VSS is wired on a V6?
On the 90 -92 V8 TPI cars for example ,the VSS signal goes to the computer first , then the speedo so if you remove the computer ......
Old Sep 6, 2013 | 01:12 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you need to also get the reluctor ring from the output shaft of the original trans and put it on the output shaft of the new trans. it's a press fit, so have fun with that..
another option: 92 (and maybe some other years) Caprices used a VSS that still used the old school drive and driven gears.. get the proper speedo gears for your rear axle ratio and tire diameter and wire that to the signal wire to the speedo..
AC Delco 213197, $70.99 at Rockauto
they also have one with a cable attachment- Delco 213201, $59.79- if you need that for some reason:
Old Sep 6, 2013 | 08:10 AM
Car: 91RS
recipient car: 91rs 3.1v6 with electronic vss and reg. guage cluster (not digital) v6 auto tranny 700r4
donor car: 89rs with 355v8 with cable driven vss and reg guage cluster (not digital) v8 auto tranny 700r4
Old Sep 6, 2013 | 10:22 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://tpiparts.net/inc/sdetail/7587
if you want to ditch the ecm internal buffer you can use a external vss buffer
Old Sep 6, 2013 | 10:38 AM
Car: 91RS
looks like the 1st link is just plug and play. but I don't understand about the BUFFER?
Old Sep 6, 2013 | 10:40 AM
Engine: Lb9
Transmission: M20
The first link will be a plug and play through the ecm. If you need to recalibrate the speedometer you can also bypass the ecm and use a Dakota digital sgi-5.
Old Sep 6, 2013 | 10:43 AM
Car: 91RS
ooohhhhhh! I think I got you now. I will be having to do this before I put the v8 in. thx.
Old Sep 23, 2013 | 03:05 PM
Car: 91RS
I had a person trade me this can u tell me that this is definitely what I need and I think that I still need to remove reluctor ring from old tranny am I correct?
Attached Thumbnails quick quest. about vss-img-20130923-00395-1   quick quest. about vss-img-20130923-00394-1
Old Sep 25, 2013 | 11:13 AM
Car: 91RS
bump
Old Apr 15, 2014 | 07:46 AM
Car: 91RS
trying to determine what color drive and driven gears came in the 92rs from factory but just thought about the factory setup in 92 did not include 15in wheels so how can I find out what drive and driven gears were in the v6 w/o having it in front of me. hind sight is 20/20 I should have had all this info b4 I got rid of it. I believe that the same gears and no. of teeth would work and all I would have had to do is take the gear of the tranny shaft and the one out of the tail shaft and transplant them into my v8 tranny and I would have been ok. now I have to do some digging and try to find whick gears are recommended for a 92rs with 3.23gear and 15in tires buy them install them onto my sc12 and hope that it works
Old Apr 15, 2014 | 05:18 PM
Car: 91RS
my car is a 92rs that had a 3.1v6 and 3.23 gears and 15in tires what was the stock drive and driven speedo gears that it came with?
$750 L98
Feb 1, 2025 02:25 PM
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
