lock up kits
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
lock up kits
Do I or would it be better if I use a aftermarket lock up kit. 87 700r4
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: lock up kits
All the ecm is doing is applying power to the tcc solonoid for lockup. lockup and unlock 3rd and 4th can be set to any desired mph lock or tps % unlock. Aftermarket like b&m uses a micro switch to activate tcc lockup. Others use a pressure switch. nothing to gain swapping.
Re: lock up kits
So no need for it unless for better control of lock up. What about drag racing isn't better to not have a locked. And locked for highway driving
Engine: Lb9
Transmission: M20
Re: lock up kits
I'm not sure how you figure its better control with a aftermarket kit, yes your tcc should be locked up during highway speeds but with light throttle can lockup at 35mph.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lock up kits
Several times I've used the lockup kit from Painless Wiring; Once in a 3.08:1-geared Camaro with a very mild 350, and it wasn't lugging even at 830 RPM at 30 MPH.
The kit is overpriced, and you can replicate it at far lower cost once you've done it a few times, but it worked very well for when I was new to such things, with good instructions and every part needed was included.
Car: 86 T/A, 89 Formula
Engine: LG4,L03
Transmission: 700r4, T5
Axle/Gears: 2:73, 3:08
Re: lock up kits
Not to jack this thread but is there a thread about wiring a switch directly to the transmission to control lockup manually? I have removed all computor control to my car with the exception of the VSS . any help would be appreciated....
Re: lock up kits
I have been interested in this as well. Found this thread through a search.
https://www.thirdgen.org/forums/tran...cc-lockup.html
Car: 82 Z28
Transmission: T400
Re: lock up kits
Install a 4th gear switch in the trans , adjust some wiring and the lock will occur automatically everytim ethr trans goes into 4th
without you needing to think about the lockup or use a manual switch
See
https://www.thirdgen.org/forums/carb...c-control.html
Engine: LG4,L03
Re: lock up kits
Thanks JOE and Vetteoz. Those are great threads with slightly different variations. should be able to use one of these for my application. Thanks again..
Re: lock up kits
The Painless setup is the most complete kit and works very well. The cost is a little high, but it is complete and no furter running around involved. I have been recommending these for years now with no complaints.
Drone358
Dec 10, 2015 08:16 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
