Flywheel and clutch suggestions needed
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
I called the engine maker just to make sure it used a standard 350 external balance flywheel. It is a blueprint engines 383, rated 420/450. Would be revving to 6k. That said, theres a lot of options. Stock, light weight, aluminum. The car is used mainly for back road driving, rarely commuting or dd. Occasional drag strip, high way pulls. I'm swapping in a T56 from a 94 Z28. I have never driven a car with any sort of modified clutch or flywheel. I saw circle track flywheels are around 10 pounds, some aluminum ones around 20, and stock ar 30. What would be the best given the driving i do?
Car: `86 SS / `87 SS
Re: Flywheel and clutch suggestions needed
There is no stock external balance 350.
We also don't know what year or rear main seal your 383 nee 350 has.
If yours is 86-up one-piece and balanced to use an 86-up one-piece rear main seal flywheel with included balance weight to match the internal balance 86-up engines, you would use the 94 Z28 flywheel and done.
If your engine is a 2-piece rear main seal, balanced to use an 85-down neutral balance 350 flywheel with no weight, there are a number of aftermarket flywheels to work with that balance, bolt pattern, and the 93-97 LT1 T56. Look for a thread by Jupiter5; he made a list.
If your engine is a 2-piece rear main seal, balanced to use a 400 SBC external balance flywheel w/ a weight, there are a few aftermarket flywheels to work with that. Some of them are simply the neutral balance 350 flywheel with a bolt-on weight.
Car: 86 Z28
Engine: 385 HSR
yes, it is a one piece rear main. i thought the 350 was internal balance because of the extra flex plates i have laying around have no weights, but my 86 305 flexplate is weighted. i think they required the 400 balancer but 350 flexplate. how would it be driving with a light weight flywheel?
