4 speed swap question
Old Sep 11, 2013 | 09:31 PM
86z89iroc's Avatar
Car: 86 z28 daily, 2 89 iroc-z's
Engine: sbc's
I have an 89 iroc with 335 stroker kit and 700r4. My question is will a 4 speed out of an 82z28 work with my engine in 89. Being a stroker the flexplate is balanced. Would a flywheel need to be different because of balance and possibly cause of newer crankshaft?
Old Sep 12, 2013 | 12:39 AM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: 4 speed swap question
If the block is from 89 then you would need the flywheel for an engine with a one piece rear seal. if the block is a two piece rear seal you need a flywheel for that type of engine. The other thing you need to know is if the crank shaft is internally balanced or externally balanced, This will tell you exactly what flywheel you need.
Old Sep 12, 2013 | 04:02 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
and hopefully the machine shop didn't do any grinding on the flexplate when they balanced the rotating assembly of the engine. if not, you could just bolt on the proper flywheel for the crankshaft and throw it together.. if they did grind on the flexplate, then you'd have to take that and the new flywheel to a machine shop for them to match the balance of the flywheel to your old flexplate.
Old Sep 12, 2013 | 07:18 PM
86z89iroc's Avatar
Engine: sbc's
ok that's what I thought just couldn't remember exactly. thanks. guy has an 82 pace car for sale in my area but its rough. the car is the 4 speed car and not sure if I could part it out but he talks like it runs body and interior is rough and engine is supposedly a remanufactured block but needs to be trailered and not sure why. any thoughts?...
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
