quick t5 speedo question
I have a t5 transfer and I and installingva 145 speedometer.
Do I need to swap out my speedometer drive and driven gears?
or
is the difference for the MPH is preset within the speedometer it's self? ?
Sorry if its kind of a noob question
or
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: quick t5 speedo question
i'm assuming you mean you currently have a t5 and your installing a 145mph speedo?
the transmission drive and driven gears are matched for the rear axle ratio gears to drive the speedo.
so yes, you can put in a 145mph speedometer without changing them
Right: the speedo sill wants to see 1000 turns of the cable per mile. None of that changes.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Often the trip odometer is broken. If so, and it's important to you, the following link provides a fix:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
JamesC
Car: `86 SS / `87 SS
JamesC
JamesC
buckeyecelt
Sep 24, 2015 05:50 AM
