swapping 10 bolt for 9 bolt.
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
I picked up a 9 bolt with 3.27's from thirdgen ranch. It was out of an 87 iroc. I have never a really taken a rear out before. I have had pretty much everything loosend up back there with replacing parts like the adjustable pan hard bar and tubular control arms new shocks. What I was wondering is it that much of a pita to actually pull the rear? Will I need to compress the springs? What should I need to know before swapping out the drum for the disc brake set up?
Re: swapping 10 bolt for 9 bolt.
I STRONGLY suggest that if you do this, you set the old springs aside at that point, and lift new ones instead.
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Im doing the same swap as we speak. 10 bolt to 9 bolt... I just pulled the rear end out last night. The thing practically fell out for me. Took no time. Springs are nothing to worry about, just put the jack under the rear and after removing the shocks and control arms, pull back and drop it out. No sweat.
Car: 87 Trans Am
I got the master cylinder and proportioning valve also the e brake cable with the 9 bolt. Will I have to use any of that? Master cylinder and proportioning valve looks the same as what's already on my car. I dunno if there's a difference in them or not.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It is not too hard but there are some fun gotchas that you can run into. My favorite is forgetting to check the threads where you bolt on the drive shaft and finding them messed up after you get the rear under the car. I would suggest running a bolt and maybe a tap through them before you slide the rear under.
Eric-86sc
Apr 3, 2016 03:52 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
