The start of my auto to manual trans swap
Car: 1984 Trans Am 5.0 HO
Engine: 383
Axle/Gears: Dana 44 4.09
Here are a few shots .
I've taken the non LSD axle out and have a Dana 44 with a 4.09 LSD from my donor car,
Any thoughts on if I should get the rear swaybar powder coated?
Engine: 383
Re: The start of my auto to manual trans swap
Here are some shots with the axle removed.
Engine: 383
The donor car is back on it's wheels with my axle, propshaft, springs and shocks.
I lowered the axles onto a flat trolley when I removed them and was able to pull the axle from the car from the side it also made it easy to put it back into the donor.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
care to divulge which manual transmission you are using?
Nice colorful garage by the way.
Engine: 383
One thing that I forgot to mention was the axle ends of the propshafts were different sizes.
Luckily the gearbox ends are the same
Also here is a shot of my rear sway bar after being powder coated.
and another shot of my garage
And this is a link to my photography on flickr
http://www.flickr.com/photos/gary-chalker/
Engine: 383
Here is a picture of the Founders performance adjustable panhard rod and adjustable control arms that arrived in the post this morning
Engine: 383
I fitted the Dana 44 axle into my car today.
Also in the picture you can see my Gale Banks Exhaust system which is mated to Edelbrock headers.
Engine: 383
I am nearly ready to remove the 383 engine and T5 trans from my donor car.
Here are a few pictures.
Today I removed the starter which I think is a Mcleod mini starter.
The T5 shifter, it says Hurst on the stick maybe someone can tell me if if the shifter part is Hurst and also if they are any good?
Also I removed the manual clutch linkage and after reading on here about how they split I was expecting the worse, after cleaning it up it's perfect [donor car only has 24,000 miles on the clock]
Engine: 383
I've removed the pedal boxes from both cars which was not that bad a job. I removed the drivers seat in both cars and then just laid on my back . I have also marked the hole to be cut in the firewall for the clutch rod [manual clutch linkage]. There is also a plate bolted on the drivers side frame rail with 2 bolts
the holes were there on the auto car but I had to use an 8mm tap to thread them. I have also swapped the heater boxes over [ donor car had no A/C] also an easy job. I also removed a MSD6200 and coil from the donor car ,it's fitted with loads of goodies. I have now put a bolt in the manual pedal box [above the clutch pedal] so that I can hopefully adjust the clutch pedal height
Engine: 383
Today I cut the hole in the firewall for the clutch rod and fitted the manual pedal box ,if anyone else is doing this I suggest putting the bolt at the top of the pedal box in first [before you push the servo through the firewall] and then the 4 nuts for the servo ,if you fit the 4 nuts first you may find that the hole for the bolt at the top of the pedal box will not line up.
Here are a couple of pics with the pedal box fitted, note the B and M auto shifter , my car is still fitted with the 305 and TH 700R4
Next job is to remove the engine and trans ,cut the hole in the trans tunnel for the T5 shifter
Then fit my 383 and T5 from the donor car after the engine has been re painted.
Engine: 383
The engine and 5 speed are now removed from my donor car. I'm going to strip the paint off the engine and re paint it.
I have now washed the 5 speed and I'm going to paint that as well
Engine: 383
All the old yellow paint was scraped off and the engine is now painted with three coats of POR15 Chevy Orange.
Car: 1992 Formula 350
Engine: 5.7 L98
I had that exact hurst shifter in my 1986 T-5 Trans Am. I wound up cutting the stick down because of how high it stood. It is so high it looks goofy. I wound up cutting the stick at the bottom and having two new holes drilled. Looked and worked wayyyyy better.
Engine: 383
Thanks for the tip. Do you have any pictures?
Engine: 383
Engine/Trans is now out of my car and I'm starting to tidy up the engine bay. I had a bit of a nightmare getting under my car I had to place paving slabs under each wheel.
The front sway bar[32mm] has been powder coated and I'm waiting for new bushes and end links to arrive.
I also have anther steering box to go in it has XH stamped on the end and a Z on the top casing is this a higher effort/quick rack and will it work OK with 15inch wheels and are there any disadvantages?
Engine: 383
I swapped
the steering box today all of the bolts and the pitman arm came off no problem
Engine: 383
I still have not got round to putting my new engine and manual gearbox in ,the new engine mounts are in along with a freshly powder coated front sway bar sitting in new bushes and end links, also new steering box fitted. After a lot of measuring I cut the hole in the trans tunnel for the gear lever.
I have also been polishing the inner wings and generally trying to tidy things up under the bonnet.
I got an Edelbrock strut brace a few days ago so I'm going to fit that after the engine/box are in.
Who else is using one of these?
I have a new torque arm bush and gearbox mount from Energy Suspension also to be fitted.
Engine: 383
I drilled out the rivets that hold the original torque arm mount and replaced it with an Energy Suspension polyurethane mount . I also changed the gearbox mount for a polyurethane one.
Next stage get the engine and box in the car.
Engine: 383
I fitted the engine and gearbox today. The engine mounts/gearbox mount and torque arm mount are all fitted with Energy Suspension polyurethane bushes. The front roll bar has been powder coated and is fitted with new polyurethane bushes and end links also from Energy Suspension.
I've also fitted a quick rack from a Camaro, Edelbrock strut brace will be bolted in later
Engine: 383
Today I tightened the gearbox crossmember and mount along with the torque arm mount [a bit of a bitch]. Also fitted the McLeod mini starter.
I fitted my centre consol back in with the manual shift plate and Hurst quick shifter and found that I had cut the hole in the right place after all
Engine: 383
I am still working on my car when I can. Here is a pic of where I am at .
Untitled by garymchalker, on Flickr
Engine bay by garymchalker, on Flickr
Engine bay by garymchalker, on Flickr Senior Member
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Engine bay by garymchalker, on Flickr Thread Starter
Engine: 383
The heater hoses came from a company here in the UK
The radiator hoses came fom ebay.com
Engine: 383
Car: 83 Z 28
Engine: LG4
Axle/Gears: dunno
The donor car has a T5 and a 383.
Engine: 383
Engine: 383
All pulleys are now fitted ,I had to use a shim on the water pump pulley to get things to line up
Aluminium pulleys fitted by garymchalker, on Flickr
and I got a short stick for my Hurst quickshifter it looks and feels a whole lot better
Long stick
Hurst shifter with 7.5 inch stick by garymchalker, on Flickr
Short stick
Hurst shifter with short stick by garymchalker, on Flickr
Aluminium pulleys fitted by garymchalker, on Flickrand I got a short stick for my Hurst quickshifter it looks and feels a whole lot better
Long stick
Hurst shifter with 7.5 inch stick by garymchalker, on FlickrShort stick
Hurst shifter with short stick by garymchalker, on Flickr Thread Starter
Engine: 383
The exhaust system is back on. I've wired up the starter and bypassed the old auto shiter wiring so the engine now turns over on the key. The MSD box and coil are fitted I just need to wire them up. Fan switch,Engine temp sender,back up lights and the alternator are wired up.
I have also started to fit Teflon braided fuel pipe
Enginge bay by Gary Chalker, on Flickr
MSD box and coil by Gary Chalker, on Flickr
Engine showing 10mm Teflon braided fuel pipe by Gary Chalker, on Flickr
Engine showing 10mm Teflon braided fuel pipe by Gary Chalker, on Flickr Thread Starter
Engine: 383
Car is now all re assembled
by https://www.flickr.com/photos/116957934@N04/, on Flickr
Hawks Third Gen wheels
Wheels and bonnet fitted
by https://www.flickr.com/photos/gary-chalker/, on Flickr
spaceghost5
Mar 27, 2009 08:06 AM
