help swaping th350 into 1991 camaro rs?
Old Oct 6, 2013 | 01:07 PM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
hello i have a 1991 camaro rs that is getting a new 383 put in it at the moment and was about to put a performance 700r4 back behind it when i was told that no matter what i did to the 700r4 it could not stand up to the new engine. so now i wondering about the th350 it was suggested as a better alternative along with a th400. so im curious a to how much work would it require to do a swap and things like to i have to get a different drive shaft because of length is it going to mount up the same oh and is there additional wiring and parts involved. sorry about how long this is i just want to make sure its the right thing for me. thanks
Old Oct 7, 2013 | 01:33 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: help swaping th350 into 1991 camaro rs?
How much power are you planing on making. The 700R4 can be built to take a lot of power.
Old Oct 7, 2013 | 05:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
do i have to get a different drive shaft
Many TH350 swap threads on here with everything you need to you use the button above
Like
https://www.thirdgen.org/forums/tran...h350-swap.html
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Cripley
Aug 17, 2015 03:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
