84 Transam axle upgrade questions
Old Oct 18, 2013 | 01:21 PM
wallyj's Avatar
Car: 84 TransAm
Engine: Vortec 383SBC
Transmission: T56, Stage 2 Ram clutch
Axle/Gears: 7.5 w/28 spline axles and 4.10 LSD
Question, I have been searching but cant quite find the answer I have an 84 transam with an open 3.23 26 spline disk brak diff, I feel the need for posi and have settled on a Detroit truetrack in 28 spline.
Question is whhat vehicles can I scavenge axles from at the wreckers that will work for me and my old disk brake car? can I use 4th gen stuff? astros and s10's? or will the axle widths be different?
I figured there would be a simple anser, but I cant find the info!!
Old Oct 18, 2013 | 01:30 PM
big gear head's Avatar
Re: 84 Transam axle upgrade questions
'90 to '92 Camaro and Firebird, period. Nothing else will work.
Old Oct 18, 2013 | 01:32 PM
wallyj's Avatar
Car: 84 TransAm
They are getting pretty scarce in the yards up here, so maybe I need a set of axles as well then, any basic ones that arent $400 a piece from summit you's recommend?
Old Oct 18, 2013 | 01:40 PM
Contact Randy's Ring & Pinion, Moser Engineering, Tom's Differentials or Jim at www.jdrace.com
Old Oct 19, 2013 | 01:04 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
ANy Camaro/Firebird 82-2002. The 93-2002 stuff will be a bit wide but you should be able to adapt it.
Now, I would find a set of 28 spline axles from a 90-92 F-body. Then, a differential from any Fbody will work as they all will fit all the way through 2002.
I have an 84, I bought 28 spline axles from Jegs and picked up a Zexel Torsen differential from a 2002 SS Camaro. It's run fine for me for the past 4 years.
Old Nov 30, 2013 | 05:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i have a pair id like one hundred dollars for but the shipping would be excessive.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
