700r4 VSS question
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
700r4 VSS question
Hey guys, I swapped the rear end in my 1991 Trans Am (2.73 to 3.45 gears) and I'm looking to order the proper speedometer gears. Stock, the car should (although I'm not certain, please correct me if anything) have 37 driven/17 tooth drive gears (both red). I need a 41 tooth driven and 15 tooth drive gear for my speedo to work correctly. However, online I'm seeing "34-39 tooth" and "40-45 tooth" speed sensors for sale. Does that mean I'll need to buy a new VSS as well?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 700r4 VSS question
most of the gears are nla even in aftermarket, get a Dakota digital sgi-5
Engine: LB9
Oh really? I found a website that offers speedo gears. Anymore info about about the device you're talking about?
Engine: Lb9
Transmission: M20
Engine: LB9
Seems a bit pricey and unnecessary for me. Thank you though.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
http://www.transmissioncenter.net/sp...0gear%20driven
I bought mine from this site but I have an 86 700R4, yours is different I think..
Engine: LB9
HOWEVER, a local Buick dealership said they can get a hold of one for me in about a week. So that just begs the question of whether or not my factory VSS will handle the larger gear. Like I said, my car right now has the 37 tooth gear with the 17 tooth drive. So would a 41/15 swap be just plug and play or would I need a new VSS to handle the larger gear??
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
For any year /engine there are two VSS units ;
one does 35 - 39 driven gear and the other 40-45 gear.
As the later is generally unavailable ,the usual trick is to turn the former VSS 180 degrees so the shaft offset is greater to suit the larger gear
Running too big a driven gear on a VSS will quickly chew out either that gear or the drive gear
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Engine: LB9
The 700R4 / 4L60 can use either a cable drive or VSS depending which unit is installed
Engine: LB9
Hey guys, I picked up the speedometer driven gear from the dealership today (cost about $18) and threw it in the car along with the gray drive gear. I flipped the VSS around like vetteoz suggested and it works like a charm now. Speedometer is spot on. I'm just surprised that the dealership of all places was able to get the speedo gear for me. Discontinued everywhere else! Must've been an NOS item they got a hold of for me.
Iroc8t8
May 4, 2026 08:09 PM
