Slave cylinder pushrod bushing?
Old Oct 28, 2013 | 05:46 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
Is this a bushing? Or is it something that is used for packaging the cylinder which should not be installed during use? If it is a bushing, are replacements available?
Old Oct 28, 2013 | 06:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Slave cylinder pushrod bushing?
It's supposed to remain in place.
Assuming I had some lying around, would I try a piece of delrin and whittle it with a dremel? Yeah.
If I didn't, I'd buy a $30 slave cylinder and consider it money well spent vs. my time.
Old Oct 28, 2013 | 07:03 PM
It's supposed to stay in place, but the consequences of it falling out are minimal.
I'd bet that something well above 90% of all cars that came with that in them have long since lost them.
Looks mostly like a pre-assembly "keep it from falling apart" deal to me.
I wouldn't lose too much sleep over it. The built-in self-adjustment range of the cyl will EEEEEZYLI take up the slack.
Old Oct 29, 2013 | 02:47 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Like others have said, it won't make much of a difference if its there or not, if you want you could add some grease to the ball end. When new it's used to hold the rod compressed tell its installed in the tranny and when you push in the clutch the straps snap and the rod goes into place.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
