Shims at the carrier....???
Old Oct 29, 2013 | 08:46 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
So here's my question... Dumb to some but oh well.. Can you press on the carrier bearings and shim out the races? Or... Is it correct to shim out the bearings off the carrier and leave races alone on there seat?
Old Oct 30, 2013 | 04:04 AM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Re: Shims at the carrier....???
Shims go between the bearing race and the housing, yes. The pinion gear gets the shims between the pinion and the bearing.
Old Oct 30, 2013 | 06:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Old Oct 30, 2013 | 06:31 AM
Most (all? not sure) GM rears were originally built with the shims on the pinion shaft behind the cone. Some models of rear from other mfrs though, DO shim the races in the housing, instead of the cone on the shaft.
I don't see any reason it wouldn't be possible to do it either way, if you can get shims of the right size. The housing is the variable thing, that generates the need for selecting shims, to begin with; not the pinion or the bearing.
Of course we all know what happens when something goes wrong with that procedure... it's not without risk.
Old Oct 30, 2013 | 07:01 AM
big gear head's Avatar
Most GM rear ends, including the 7.5 10 bolt, us shims between the bearing race and the housing. Many of the Dana rear ends, like the 60, have the shims between the bearing and the differential. This requires pressing the bearing off and on each time you make a backlash or bearing preload change. The Dana rear ends also have the pinion depth shims between the race and the housing, which requires driving the race out and in each time you make a pinion depth change.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
dimented24x7
Sep 17, 2015 06:58 AM
