Trans mount location
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Can someone confirm with me that a t-5 and 700r4 trans mount is in same location. I want to purchase a UMI crossmember and torque arm with driveshaft loop. I am currently using a 700r4 and may switch to poweglide. UMI told me they don't offer one for both. They do sell one that fits t-5 and turbo 350 that looks to me will work....thanks Frank
Re: Trans mount location
Yes they are the same.
T-5 and 700 are the same length; use the same crossmember; and locate the mount in the same place.
350 and Glide are also the same, but different from the above.
Anything that fits 350 or Powerglide will not fit T-5 or 700. (except the mount itself) Crossmember most certainly must be different.
Car: 1990 IROC-Z
Engine: 355/AFR 210
colton_carlson
Mar 8, 2019 12:21 PM
